Hi ,
My Desktop system is having strange issues from past couple of weeks.
Actually the biggest of them that is of my prime concern is that "Its getting restarted every once in a while, itself".
Sometimes it reboots 10 times in a minute, sometimes once in an hour , and sometimes it keeps on rebooting like as it were programmed to be in an infinite reboot loop .........
It doesnt seems to be a software or O\S issue , as the system is rebooting even when its booted up , or when I am setting up the BIOS , or even when I am choosing which OS to boot....
sometimes it boots up in middle of any important work...
Currently installed Operating system are
-Windows Seven Ultimate
-Windows Xp Sp3
-Ubuntu10.04 (Missing Grub ..so it doesnt appears in bootup anyhow,but its installed in a seperate part on hdd)
The physical configuration of my Computer System is
Intel Core 2 Duo 2.2 Ghz 2mb l2 cache mem,(~3.5 Years Old)
Intel DG14RQ motherboard ( ~10 months old)
3 Gb DDR2 ram , dual channel ,(1gb Apacer (3yr old) and 2gb kingston (10 months old))
250gb Sata HDD WD Sata 1(Boot Config installed ), 1024GB Sata HDD WD sata 2,
Dvd-R Lg Sata 3,
Nvidia GeForce 8400gs Zotac ,
I also use samsung smb2030 syncmast lcd on DVI cable.
Now can any one tell me the reason why My computer keeps on rebooting at any point of time..???
Is there a conflict in Memory , cause it dual channeled.
Also sometimes the grfx card fails to work , or say sometimes it appears like the system is running in 8 bit color mode , cause from boot-up screen till windows logon screen the screen color looks pathetic and messy with green green and white lines all over the screen..........
I fixed this problem last month by diassembling and then re-assembling everything out of the cabinet....but this has appeared again and I am facing this issue from past three four days .,
This time I left Bio setting back to original -load optimal settings- but it didnt gave any results. .
-Windows Xp Sp3
Dvd-R Lg Sata 3,
