Hey everyone, I've read a bunch of topics on this site before and figured you guys could help me out, I'm looking to spend anywhere between $1,500-$2,000 on a good gaming build. I did a bit of research before I chose what to get and was wondering if anyone had any suggestions or changes in mind, and if so I would greatly appreciate any advice, also I'm not really looking to overclock, if so then only going to a little bit...
CPU: Intel Core i5-760
MoBo: Intel BOXDP55KG
RAM: OCZ Platinum 4GB DDR3 (2 x 2GB)
HDD: (2x with Raid 0) Seagate Constellation ES ST3500514NS 500GB 7200 RPM
GFX: GeForce GTX 470 (From Gigabyte with a factory overclock I believe)
Case: LIAN LI PC-B25FWB
The case was a fairly quick choice with only a bit of research and so far I can't seem to find a PSU with everything I need without going overboard.
Also if it matters I'm using...
Monitor: LG W2486L (1920x1080)
Speakers: Logitech Z-5500 (5.1)
Both of which I already bought, any feedback would be very helpful and appreciated, thanks again!
