first of all.. no hate. I could only afford mid range pcs for years but I finished college and got my first good job .. and saved
See below for background info
Computer (~$3600 on 02NOV10)
CPU - i7-980X- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115223
Motherboard - ASUS Rampage III Extreme - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131642
Memory - CORSAIR DOMINATOR 6 GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
Graphics - GeForce GTX 480 (2)- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130551
Hard Drive - Crucial RealSSD C300 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820148349
Storage Drive - large external USB 3.0 at later date
PSU - Antec TPQ-1200 1200W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371032
Case - Corsair 800D- http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001
Optical drive - LG WH10LS30K 10X Blu-ray Burner - http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181
Watercooling (Koolance everything ~$1400 on 02NOV10)
System - ERM-2K3UCU - http://www.koolance.com/water-cooling/product_info.php?product_id=1030
CPU block - CPU-360 - http://www.koolance.com/water-cooling/product_info.php?product_id=978
GPU block - VID-NX480 (2) - http://www.koolance.com/water-cooling/product_info.php?product_id=1017
Nozzles - need 8? - http://www.koolance.com/water-cooling/product_info.php?products_id=399
Quick Disconnects - 2 female - http://www.koolance.com/water-cooling/product_info.php?product_id=1080
Quick Disconnects - 2 male - http://www.koolance.com/water-cooling/product_info.php?product_id=1082
+tubing
+coolant
My background and needs-
First PC built in 2002, second in 2007
Never built a watercooled PC
Crysis my favorite FPS/game of all time.. until the retarded aliens showed up and ruined it. Im hoping Crytek has fixed the aliens for Crysis 2, and consider the MAX deadline for this build to be March 22 (buy late February).
Crysis 1 gameplay at native 2560x1440 and high settings while never falling below 30 fps a must. hence 480 sli
My first PC sounded like a jet engine, and second sounded like a small jet engine... so id like a quieter PC for once. hence watercooled
Other games.. portal 2, bulletstorm, duke nukem forever, rage, diablo 3, bioshock 1/2/infinite, everquest
Some justification for picks above-
1400 bucks on water cooling may seem a bit retarded, but im most comfortable with koolance for my first attempt plus its sexy for my first dream pc. Water cooling kinda must have so I can run 480s without crazy noise
i7-980x because I might want a third 480 eventually and anything under an i7965 will bottleneck them.. also im new to overclocking and the 980x with rampage 3 will allow me the most leg room to fiddle with
Unsure picks-
Im expecting the OCZ RevoDrive X2 or Intel X-25M G3 to be my SSD of choice... but when will we see benchmarks?
When will we see a single gpu card with more power and less noise than the 480x?
When will we see a processor overtake the 980x in performance?
Please let you know what you think.. and let me know if I need to buy anything else from koolance. Thanks.
+tubing
+coolant
Unsure picks-
