Strange booting problem
Hi all, this is one of my first posts here, and I've got a small problem with my newly bought system.
If I shut down my computer for a few hours and want to turn it back on, I hear the fan spinning for a second or two and the neon lights turning on, and all of a sudden all shuts down like if I pulled the power cord off.
That's my motherboard, Asus P6T SE equipped with a Core i7 930.
http://ebxtechshop.com/en/product.php?id=81881
I've got a X-Power-Pro PSU bought from newegg, 650-watt.
As long as the ATX cable is plugged, the PC turns on then turns off in 2 seconds. If I unplug + replug the cable, all powers on well, but if I tilt the tower it will turn off.
The problem stayed for a few days, then was gone. Recently, after a few weeks without doing it, the problem reappeared.
Some people told be about flashing my BIOS, but it didn't do the trick. Any ideas on that?
CPU: Intel Core i7 930 @ 2.8GHz (overclock @ 3.4GHz)
Motherboard: ASUS P6T (2PCI, 2PCIE, LGA1366)
Graphics: ATI Radeon HD 5750 DDR5 1GB
Hard drive: Hitachi 1TB HDS721010CLA332 7200RPM 32MB cache
RAM: 3x Kingston triple-channel DDR3 (6GB)
PSU: HEC X-Power-Pro 650W
Screen: LG W2243 HD 1920x1080 16:9 dual-screen
OS: Windows 7 Professional Edition 64-bits
Box: Sagitta Raidmax power
1 answer Last reply
More about strange booting problem
  1. Hello and welcome to THG.
    Sounds like a loose connector. Try to reconnect everything and tilt the tower and feel wiring to see if you notice anything loose.
Power Supplies Components
