Hi everyone,
I posted about a week ago asking whether the Radeon 5770 would be compatible with the Asrock N68C-S UCC and was told yes. But now I have a problem i've been trying to figure out for the past 4 days, please help!
Here are my computer specs at the moment in case they are the problem:
Motherboard: Asrock N68C-S UCC
CPU: Athlon II X4 635
Graphics: Radeon 5770
Power unit: 450 watts
The problem is that the card just isn't being detected, when I install the ATI drivers nothing happens. The fan on the graphics card is spinning, everything is corrected properly (I hope). I have put the monitor into the VGA port on the card, and the monitor is working fine. But its stuck in "Vga Save" mode. I've reinstalled windows on multiple occasions (it might be notable that I don't have fast internet so can't update windows xp so am currently stuck with the SP1 from 2002, would this cause any problems?) .net 2.0 etc is installed so I can't see it being a software problem.
Any ideas as to what it might be? I've tried driver sweeper, but I just changed the motherboard, formatted the hard drive etc so I can't see why thats a problem. Are any of the hardware specs a problem? Thanks a lot for reading, hope you can help.
