Help With Creating Custom-Built Rig
Asus M4A87TD-EVO
http://www.asus.com/product.aspx?p_id=nlwyri9wlniyhaaa&templete=2
or
Asus M4A88T-M
http://www.asus.com/product.aspx?P_ID=Gu2wNGbZ0LY8zKvu
Which do you think I should buy?
Please click on the links I really can't decide because both are really good.
I can only buy from the local store so there are very narrow hardware choices.
These are the only MoBo's I can afford right now.
Since I had unexpected expenses I decided to not buy the GPU (GTX 460) for the mean time (But yes I will still buy it)
The 1st choice seems to have better features for OC'ing and others but it does not have Onboard Graphics which I will need since I can't afford the GPU yet but the 2nd choice has Onboard graphics but seems to have less features (I'm not sure but please do click the links if I am wrong good folks.)
I will use them with:
Processor:
AMD Phenom II X2 555 3.2GHZ BE (Hoping to unlock to Phenom X4)
GPU:
Palit GTX 460 768MB
HDD:
2x Western Digital 500GB Caviar Blue SATA 3 Total:1TB
RAM:
2x Geil 4GB DDR3 1333MHZ Total:8GB
Casing:
Frontier Noble Gaming Casing
PSU:
Rapter II 500W
Monitor:
Dell Ultra Sharp 20 Inches That supports native resolution of 1600x1200
I am still about to buy these.
Please tell me if something is horribly wrong with this build.
The total cost of this Rig is PHP22,500 ($500) (Excluding Monitor)
I will use it mostly for gaming, school stuff (Adobe Photoshop etc.) and Mild Overclocking.
It's my first time to actually make a custom-built rig.
So sorry for anything noobish or irritating.
THANK YOU ALL FOR YOUR ANSWERS!!!
Cheers,
Tristan
2 answers Last reply
More about help creating custom built
  1. http://www.asus.com/product.aspx?P_ID=Gu2wNGbZ0LY8zKvu Is better for your build and needs.
  2. drop 4gb of ram, buy 4gb later, drop 1 hdd buy 2nd later?
CPUs
