Hello again, I'm back for yet another question to ask, since you were all so helpful in the past.
I have a computer that's a year - a year and a half old. It's running AMD Athlon 7750 Dual-Core @ 2.70.
I will post a picture to show you what I am talking about. But first, how hot can an AMD 7750 get? I've visted other sites that say 65 C is the cut off point and they will turn off after that. Others tell me up to 75 C. Another question of mine is how accurate is HWmon?
My cpu has gotten up to 96 C and idols at 46 C. I'm not 100% sure at what I'm looking at on HWmon when it comes to voltages, but if you could help me out and tell me if you think it's just a sensor problem, I would really appreciate it.
Thanks in advance,
Dru
-Edit
For some reason, whenever I try to post a picture that you can see (bigger then 640x480), the picture either doesn't show up, or the link takes you to a 403 Forbidden page. So, here we go
Voltages
Value Min Max
*CPU VCORE 1.04V 1.04V 1.34V
*VIN1 1.10V 1.10V 1.10V
*+3.3V 3.04V 3.02V 3.04V
*5V 5.05V 5.03V 5.08V
*+12V 12.16V 12.10V 12.16V
*-12V -13.50V -13.50V -13.44V
*+5V VCCH 5.08V 5.05V 5.08V
*VBAT 3.34V 3.34V 3.34V
Temperatures
*THRM 56C 49C 108C
TMPIN0 56C 49C 108C
TMPIN1 47C 44C 54C
TMPIN2 49C 46C 54C
AMD Athlon 7750
Core #0 42C 35C 96C
Core #1 42C 35C 96C
Powers
Processor 60.90W 60.90W 98.05W
NVIDIA GeForce 9800 GTX+
Voltages
VIN0 0.95V 0.95V 1.20V
Temperatures
48C 46C 78C
Thanks in advance,
Dru
-Edit
Voltages
Value Min Max
Temperatures
*THRM 56C 49C 108C
TMPIN0 56C 49C 108C
TMPIN1 47C 44C 54C
TMPIN2 49C 46C 54C
AMD Athlon 7750
Core #0 42C 35C 96C
Core #1 42C 35C 96C
Powers
Voltages
Temperatures
48C 46C 78C
