Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > First ever Build help
Forum CPU & Components : CPUs First ever Build help
i would just like to say ty in advance and any help is welcome.
First of all i would be using the computer for gaming and video convertions (e.g. avi-mp4), i have around £500 to spend if a save up so that would be the marker.
i would like to have a phenom 2 x4 970 but i think that in total that is just stupid as it costs like £140.
Also i am in the uk so uk sites please, no newegg, i basically need a new rig to do as stated and also i would like as my cores as possible and it to be fast. ty
Reply to scott_glossop
Basically in your pricerange you have a few options. It comes to about $700 american so I will give my advice based on that. Unless you link me to the site you will be buying from.
With that kind of budget, I recommend a phenom II 955 and a GTX460 1GB. These are the best bang for your dollar.
I also recommend 4GB of memory. No less. More might be useless though.
If you want to improve your CPU with any extra money, I recommend a core i5 2300, 2400 or 2500.
Questions that may change my answer:
-Where will you be buying from?
-What don't you need? For example, do you need a monitor, case etc?
-What games will you be playing? What resolution? What setting are you expecting to play these games at?
-Will you be video converting and gaming at the same time?
-Do you have any brand preferences?
Reply to enzo matrix
the cheapest PC retailer in UK i found is : aria.co.uk
choose a 955 , 890 chipset motherboard , 4GB DDR3 ram 1333MHz will be fine , no less than 600 watt PSU , a decent graphics card and a good looking case
about the HDD, WD black caviar is a good choice
Message quoted 1 times
Message edited by TheScorpion on 01-30-2011 at 07:11:40 PM
Reply to TheScorpion
+1 to that.
There are 1754 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 2 hours ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
