Hi, I want to buy a gts 450 card so that I can play Final Fantasy XIV, but I have a pretty weak power supply...Do I need to upgrade? If so, which power supply looks like the best value for the money? on a tight budget by the way
Thank you!
gts 450 specs- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121394
possible power supplies i want to buy-
http://www.geeks.com/details.asp?invtid=ESTAR-580-24&cat=PWR
http://www.geeks.com/details.asp?invtid=ES-650BLUE-12&cat=PWR
http://www.geeks.com/details.asp?invtid=ES-650BLACK-12&cat=PWR
http://www.geeks.com/details.asp?invtid=BFGR650WGSPSU-R&cat=PWR
my computer specs-
# Gateway LX Series LX6810-01 Core 2 Quad Q8200 2.33 GHz Tower PC
# General Features:
# Glossy black exterior
# Premium tower desktop with media control interface
# Microsoft Windows Vista Home Premium 64-bit w/SP1
# Intel Core 2 Quad Q8200 2.33 GHz 45nm quad-core processor
# 1333 MHz FSB speed, 4 MB L2 cache
# NVIDIA nForce 720i chipset (MCP7A-D)
# 8 GB (8192 MB) DDR2 PC2-6400 800 MHz RAM Dual-channel memory
# 640 GB 7200 RPM SATA II hard drive w/16 MB cache
# No floppy drive
# 18x DVD±RW DL with Labelflash technology
# 15-in-1 memory card reader
# NVIDIA GeForce GT120 PCI-Express video card with up to 1 GB shared memory
# Analog/Digital TV Tuner with 3-D comb filter
# 8-channel (7.1) High Definition audio with Dolby Home Theater sound
# Integrated 10/100/1000 Gigabit Ethernet LAN
# 56K ITU V.92 ready Fax/Modem
# Vista Media Center remote control included
# 400W power supply (100-127V/220-240Vac 9.5A, 50/60 Hz)
# Multimedia keyboard included
# USB mouse included
# Amplified USB-powered stereo speakers
# Motherboard Features:
# One (1) PCI Express x16 slot (occupied)
# One (1) PCI Express x1 slot (occupied)
# Two (2) PCI slots
# Six (6) SATA ports
# Four (4) 240-pin DIMM slots (occupied)
# Front I/O Ports:
# Memory card slots
# Two (2) USB ports
# Headphone jack
# Microphone jack
# One (1) IEEE 1394a port
# Composite A/V
# Rear I/O Ports:
# Two (2) PS/2 ports
# One (1) HDMI out
# One (1) dual link DVI-I port
# One (1) VGA out
# Four (4) USB 2.0 ports
# One (1) RJ-45 Ethernet jack
# One (1) RJ-11 fax/modem jack
# Line in, line out, microphone jacks
# Side, rear, c/sub audio jacks
# Composite Audio L/R
# S-Video out
# ATSC antenna
# TV antenna
# IR Blaster 1
# IR Blaster 2
# IR Receiver
# Case Features:
# Two (2) 5.25-inch external drive bays (one occupied)
# Two (2) 3.5-inch internal drive bays (one occupied)
# Two (2) 3.5-inch removable trays for SATA hard drives
# Illuminated Media Center touch controls
# Pop-out A/V panels
# Case Dimensions:
# 17.7 x 7.5 x 19.6.-inches (H x W x D)
# Weight (system only): 31 lbs.
Thank you!
my computer specs-
# General Features:
# No floppy drive
# Two (2) PCI slots
# Front I/O Ports:
# Memory card slots
# Two (2) USB ports
# Headphone jack
# Microphone jack
# Composite A/V
# Rear I/O Ports:
# One (1) HDMI out
# One (1) VGA out
# S-Video out
# ATSC antenna
# TV antenna
# IR Blaster 1
# IR Blaster 2
# IR Receiver
# Case Features:
# Case Dimensions:
