@jmwpom3: The CM Storm series is a very poor suggestion. They're overly expensive, offer only decent airflow (opposed to great airflow) and are really small (comparatively). Off the top of my head, the Coolermaster Centurion, Antec 300 Illusion, Coolermaster 690 (or 690 II), Antec 900 (or 902) and HAF 922 would all be better at lower prices.
???? Have you actually used the Storm Sniper Black edition? Only decent airflow? I want some of whatever you've been smoking because that thing's a wind tunnel. 3 X 200mm 110 CFM fans (front, side, top), 1 x 120mm 69 CFM rear top exhaust fan, space for a 140mm or 120mm bottom fan (which I installed for kicks...not even needed really, and dust filtered mesh on entire front bezel, 90% of the side panel, and on the top and bottom fan mounts, plus the rear has slotted expansion card slot covers and more vent holes for exhaust. At full load, the tempurature inside my case increases maybe 2° tops from ambient temps. THe cores and gpu get hotter but the graphics card vents out the back and the 212+ on the cpu is placed perfectly to feed the hot air to that 120mm exhaust. Whatever doesn't get pulled out by that gets dissipated by the top 200mm 110CFM exhaust.
And SMALL!!??? Again, have you seen the Sniper?? It could almost be labled a full tower! Read the reviews as that's what everyone says. It's the size of an Aleinware case, more or less. Larger than all the ones the OP listed:
Sniper: 22.30" x 10.00" x 21.70"
902: 18.60" x 8.60" x 19.40" (Scout beats this one)
BX-500: 22.36" x 8.46" x 18.90"
CM 690: 20.65" x 8.39" x 18.98" version II: 20.80" x 8.40" x 20.10"
300 Illusion: 18.30" x 8.10" x 18.00" (scout even beats this one)
CM Centurion: 18.90" x 7.95" x 17.13" (scout beats this one too)
your Haf 922: 22.20" x 10.00" x 19.70" - Still not as big as the Sniper.
So, exactly how is it "really small"???? It's bigger than all of these. And the Scout is bigger than some:
Scout:19.20" x 8.60" x 19.50"
Pricey? A little bit with the Sniper, but not overly so. $79 for the scout is more than competetive with all the cases you've listed; even cheaper than most at the $79 price tag on it right now. I'd happily take the Storm Scout over any of them. The Sniper is more($139), but what you get for that is huge. But to say the airflow is only decent is the understatement of the century. Now, I might buy that statement with the Scout. But it still has decent airflow, especially if you add the 2 x 120mm fans to the side window.
Yes, I'm a bit of a Storm Series fanboy. But, not without reason. The quality of these cases is incredible. I've used all the cases you'v mentioned and the HAF is the only one I'd say is close in quality/durability. Outside of the Lian Li and other really high end cases, I don't see anything that offers what the Sniper does. And the Scout comes in with a huge honorable mention. It has that feel like you could drop it off a building then pick it up and keep going. (exaggeration obviously, but you get the point)
Now, for the ram, I agree with you. As I said, I'm using the G.Skill ripjaws in my system. I just mentioned that I have used OCZ in the past and been happy with it. In fact, that was my recommendation to the OP - find some Trident or Ripjaws. The rest of that was just my past experience.
As for the SSD...Here's the issue. Nowhere in the post did the OP state he's looking for budget build reccomendations. In fact, the parts he selected to begin with suggested just the oposite. You seem to be shooting down my suggestions on pricepoints But even so, my advice here was to get two spinpoints and throw 'em in a raid, which would be cheaper. Then I just happened to muse on why he was willing to spend so much on Ram + MB and over $200 on a 2TB HDD from Seagate, why not use that for a small SSD or high rpm HDD (Velociraptor) for the OS. So, I don't really see what it is you didn't like about that.
