Just put everything together, the lights and fan came on, dvd drive opened, but it isn't connecting to my TV (I tried VGA and HDMI) anybody have any ideas?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211&cm_re=intel_i7_950-_-19-115-211-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&cm_re=750w_corsair-_-17-139-006-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=hyper_212%2B-_-35-103-065-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102909&Tpk=sapphire+6870
windows 7
Also there are some prongs at the end of my harddrive, and i'm not sure what they plug into.
Thanks for the help.
windows 7
