*Update*
Currently, I can't even run my computer for more than an hour without a shutoff. I've completely undone the overclock and done a System Restore back to just after I got the card. The fan noise isn't a problem anymore--I just want to be able to use my computer. Any ideas what is causing this?
**Original Post**
I just got a Radeon HIS 5830 card. I'm running 6016x1200 eyefinity on it, and I love the card.
There are a few problems I'm having with software and overclocking.
First, when the computer boots up, the fan fluctuates between normal and slightly higher than %50 speed at about a 1 second interval. It produces a WEOooWEOoooWEOoooWEOoo noise that is just awful. I can fix this in Catalyst by manually setting the fan to %50, where I can't even hear it (which is great). But I don't want to have to redo this every single time I boot up my computer. That's ridiculous! Any ideas for other solutions?
Secondly, I've been a little dissatisfied with my fps and graphics quality on my large resolution. I found that by using the Catalyst ATI Overdrive software, I could OC it (to the maximum allowed) and get awesome results. I turned my clock from 800 to 875, and it passes all the stability tests and the temps never go above 60. No artifact, and my games worked great. However, my computer would, after about an hour, turn itself off without so much as a warning: first the displays, then the rest of the computer (takes about 2 seconds). Windows never claims a hard power off and asks for safe mode like it usually would. It's super frustrating! I even saw this happen and was watching the temps when it did-- 57 degrees, which I've seen it go above with no problem. Some games are almost unplayable at stock clock, but with the OC it's the best gaming experience ever! Any ideas for why the computer is turning itself off and how to fix this?
Next, I tried ATI Tool to OC instead, as a possible solution. I couldn't get it to install because "Windows will not accept unsigned drivers." I disabled driver signing in gpedit.msc but still no luck. Is this program worth using? How can I get it to even install?
Other than these couple problems, I'm really pumped about the card (when it's OC'ed) and I love Eyefinity. Any help on these couple problems would be great, thanks.
**Original Post**
