Still working on an interesting problem.
Currently the system will restart 2-15 times in a row before posting properly and getting into windows 7. Initially I couldn't even install windows. While expanding windows files at 0% the system would always restart. I solved this by using an external dvd drive. While using the external drive it would install.
Once the system does post and gets into windows it will run fine while doing low intensity processes. However, if I try to use the internal dvd to install software it will restart instantly. If I use the external dvd to install software it will get midway through the install before restarting. The system is much more stable when using the USB attached dvd drive.
So far I have put in a different motherboard, tried different gfx cards, tried each stick of ram individually. When I run memtest it stops at 7% and will not continue. I have tried two different dvd drives as well as different connections and ports. CPU temp has been at 30 C idle. After a restart the CPU temp is not elevated.
Any ideas or thoughts would be greatly appreciated.
System specs:
Rosewill Xtreme Series RX950-D-B 950W (Yes I know I should have went with a better PSU)
40GB SATA II MLC Internal Solid State Drive (SSD)
Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX
EVGA 012-P3-1470-AR GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5
System specs:
