Just recently installed a 500gb Western Digital in my new system. Every second or so, when idling, the drive makes a soft "tick" noise. It's not something I would describe as the "click of death", but it still concerned me since the noise repeats itself frequently even when not writing. I ran chkdsk and the "data lifeguard" utility which came up with zero issues.
Based on troubleshooting steps from WD, I tried running the drive with the SATA3 data cable unplugged, with just power provided. With the data cable unplugged, the ticking stops. I replaced the cable and tested in a different SATA3 port in the MB. Ticking continues.
Is the drive bad?
Intel Core i5-3470 Ivy Bridge 3.2GHz Quad Core
ASRock Z77 Extreme4 LGA 1155 Intel Z77 MotherBoard
Western Digital WD RE4 WD5003ABYX 500GB 7200 RPM SATA
HIS Radeon HD 7850 1GB 256-bit GDDR5
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
OCZ Fatal1ty 550W Modular Gaming Power Supply
Is the drive bad?
