Hi,
I have this ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
It is rated at 8-8-8-24 at 1600mHz, but I want to run it at 1333mHz because I don't want to enable XMP on my machine (disables turbo). What timings should I run this at? If I look at CPU-Z, it shows timings:
XMP-1600: 8-8-8-24, tRC 34, Command Rate 2T
JEDEC #4 (685mHz, the closest to the speed I want to run it at): 9-9-9-24, tRC 33, blank Command Rate
I thought ram rated for higher speeds but run at a lower frequency (1600mHz ram running at 1333mHz) is supposed to decrease the timing, not increase it?
