Will a DDR3 work as it should work on a DDR2 motherboard?
October 4, 2011 6:46:27 AM
My motherboard manufacturer is HP PAVILION 06 and the model is Asterope. I want to know what other RAM will it support other than DDR2?
a c 125 V Motherboard
October 4, 2011 6:50:19 AM
If your MB supports ddr2, then no other kind of memory is supported, you must use ddr2.
m
l
October 4, 2011 7:07:33 AM
^ Yes. DDR3 RAM is not compatible with DDR2 slots.
m
l
a c 156 V Motherboard
October 4, 2011 7:09:59 AM
The DIMM sockets are different. In addition to the electronic incompatibilties, DDR3 DIMM's will not physically fit in a DDR2 socket.
m
l
