I have been having issues with my Asus m4a79xtd evo mobo since I purchased it in March, and it may just be a bad motherboard but the symptoms and inconsistencies with issues have boggled my tech friends and myself for quite some time so I thought I would visit here. This was my first PC I built myself and when its working it works great.
specs
Previously:
Now:
Instability issues forced me to check out each dimm slot with each stick of memory. Either stick works in slot B1 but neither works in slot A1. Using both sticks in A1B1 also is ineffective. When sticks are in this slot the computer does not even POST, the single beep never occurs telling me that no VGA is detected. I rebuilt the entire mobo inside the case and reapplied thermal paste but this did not solve anything, it seemed slightly more stable but the problems snowballed again quickly to the point I'm at now where using slot A1 doesn't allow a POST.
Next, I took my mobo out of its case and built it on my desk, where it sits now on a piece of cardboard, with both sticks of ram in A1 and B1, working flawlessly as I type this.
In your opinion is this a motherboard issue, a ram issue, or a case issue? I am becoming desperate for help and appreciate any insight.
specs
ASUS M4A79XTD EVO MOBO
PhenomxII 820 deneb cpu
2x2 gigs gskill ram: F310666-CL8D4GBHK, on the qvl
Asus Geforce GTS 450 gpu
Rosewill wireless lan card
Xigmatech heatsink with fan
Corsair tx650w PSU
case: Xigmatech Utgaard
Corsair tx650w PSU
Previously:
The issues started about a month after I had it, I was tinkering around with OC'ing the CPU (nothing crazy, never got above 75 C and never exceeded any voltage parameters) until I had it at a stable and easy 3.3 ghz. I think the OC was stable because I could play demanding games for extensive periods and also memtest and prime95 were stable for >12 hours. A few weeks after I OC'd the CPU and GPU I ran into a spectrum of BSOD's. Also the computer was least stable after it went to sleep and was trying to awake.
This is where it got weird, when the computer was cold, or hadn't been booted for a few hours it would sometimes boot and run fine for 5-10 minutes and then BSOD. Other times it would freeze mid POST. And even other times it wouldnt even POST or give me the 1 beep signifying my GPU was outputting to the monitor. The problem was exacerbated whenever I would try to come out of sleep mode. Usually once the computer was active for over 30 minutes it wouldn't crash no matter how long it was in use.
I began to mess with the ram and found that 1 stick in DIMM_A2 by itself is unstable while the same stick was stable in every other individual slot. The mobo is designed so 1 stick will work in any slot but two sticks must be matched A1B1 OR A2B2. A2B2 were designed for better OC's so thats why I initially chose those. I thought this wasn't a huge deal so I began using A1B1 primarily and reset all OC's to factory settings. A1B1 setup was stable for some time before the issues crept up again, albeit slowly. I decided to take my mobo out of its case and rebuild it on my actual desktop on top of a piece of cardboard. It never had any instability issues on the cardboard, but clearly that is not ideal. After a week or two I placed it back in the case where it was again stable until the issues began slowly happening at an accelerating rate which leads me to now.
Now:
