Solved
Where do I connect the Power LED cable from 650D to motherboard?
I have a Corsair 650D case and an ASRock z68 Gen3 Extreme3 motherboard. There are a set of cables from the case (for front panel) such as HDD LED, Power button, reset switch etc. I have connected them all successfully to the motherboard apart from the Power LED cable, there are 2, single pin cables, 1 with +, 1 with -. I have located the PWLED socket on the motherboard however the motherboard itself doesn't show + or - on it so I don't know exactly which cable connects to which pin. Could anyone help out here??? Sorry if this is a stupid question but its the first time I'm building a computer from scratch.
3 answers Last reply Best Answer
More about where connect power cable 650d motherboard
  1. Best answer
    The polarity normally is indicated in the manual. Try it one way and if doesn't work, then reverse it. You can't harm anything.
  2. thanks i finally got it to work haha
  3. Best answer selected by aleckazee.
Motherboards Cable LED Monitor Power
