gerry410 Distinguished Jun 17, 2010 577 0 19,010 Nov 8, 2010 #1 AsRock x58-xtreme mobo Intel Core i7 930 Mhz CORSAIR DOMINATOR 6GB (3x2GB) 240-Pin SDRAM DDR3 1600 (PC3 12800) CMP6GX3M3A1600C8 CM 690 case CM 750 watt ps CM Hyper N520 PowerColor Radeon 5850 gpu Asus CD ROM M-audio Studiophile AV 40 speakers
Solution deadcold94 Nov 8, 2010 please follow this http://www.tomshardware.com/forum/261222-31-build-advice allows us to help you alot more
O Outlander_04 Titan BANNED Nov 18, 2008 20,308 4 74,960 Nov 8, 2010 #2 depends what you are using it for Upvote 0 Downvote
deadcold94 Distinguished Aug 18, 2010 109 0 18,690 Nov 8, 2010 Solution #3 please follow this http://www.tomshardware.com/forum/261222-31-build-advice allows us to help you alot more Upvote 0 Downvote Solution
deadcold94 Distinguished Aug 18, 2010 109 0 18,690 Nov 8, 2010 #4 btw 5850 so last month .... no but really look at 6870 or 6850 Upvote 0 Downvote
gerry410 Distinguished Jun 17, 2010 577 0 19,010 Nov 15, 2010 #5 Outlander_04 : depends what you are using it for You didnt answer the question ! Upvote 0 Downvote
gerry410 Distinguished Jun 17, 2010 577 0 19,010 Nov 26, 2010 #6 Best answer selected by gerry410. Upvote 0 Downvote
Maziar Champion Jul 20, 2007 21,707 1 52,960 Nov 26, 2010 #7 This topic has been closed by Maziar Upvote 0 Downvote
