New build and new case for current build.
Hello,
I am building a new PC and upgrading an existing one.
Current PC:
Case: Thermaltake Soprano
Motherboard: MSI K9A2 CF - V1
CPU: AMD Athlon 64 II 5200Mhz @ 2.7Ghz
GPU: XFX ATI Radeon HD 4890 1GB GDDR5
RAM: Corsair XMS2 DDR2 - 4GB
HD: Western Digital 320GB HD 7,200RPM
Optical Drive: Sony Optiarc
I am upgrading it to;
Case: Antec 902
Motherboard: I have the choice of:
MSI 880GM-E41 880G Socket AM3
Asus M4A87TD/USB3 870 Socket AM3
Asus M4A88T-V EVO/USB3 880G Socket AM3
ASUS M4A88TD-M EVO/USB3 880G Socket AM3
I'd prefer an ATX motherboard.
CPU: AMD Athlon II X3 445 3.1 GHz - Socket AM3
RAM: Corsair 4GB (2x2GB) DDR3 1333MHz
Optical Drive: Sony Optiarc x2
EXTRAS:
http://www.ebuyer.com/product/51686
http://www.ebuyer.com/product/138706
http://www.ebuyer.com/product/138705
For the new build;
Some of my old parts are going in here:
GPU: Sapphire HD 3650 512MB DDR2
What do you think? Everything adding up?
3 answers Last reply
More about build case current build
  1. Looks good to me! I had the Asus M4A87TD-EVO motherboard before and quite liked it... the USB3 version was just about the same, and should work fine for you.
    I'd be tempted to go for a Phenom II x4 955 if I were you, it would give you more of a feeling like you just upgraded...
  2. The Asrock 870Extreme has a price cut and is currently the only 8/8 CFable 870 so i'd have a long look at that hehe
  3. Or would you recommend the: Gigabyte GA-880GA-UD3H 880GA Socket AM3 8 Channel Audio ATX Motherboard?
    http://www.ebuyer.com/product/218921
Homebuilt Cases Socket HD Systems Product
