So I recently got a 650 watt power supply i plug it in and the pc turns on perfectly but when i turn on the pc my internet goes out and when i turn it off my internet connects again any idea's?
your power supply is a lousy piece of crap and i suggest you take it out back and have it meet its new friend the garbage can.
look at the first four or so results: http://www.youtube.com/results?search_query=computer+power+supply+repair+forum&aq=f
(yes they are my movies)... thats what your psu is going to do: explode. and its going to cause a power surge that could damage every other component in your computer.would you rather spend $50 on a good psu or $500 on a new pc?
stick to a high quality brand like antec, corsair, seasonic, etc. and you will have an error-free reliable pc.
now, all 2wire modems from a long time ago up until revently had issues with the little wall power adapters failing. i would get that checked out.
on a side note i have a weird problem where if i used WEP security on my wireless router, when my pc connected the router would continuously reboot. So i had to use WAP.
