Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > [Solved] Recommend me a sound card
Forum CPU & Components : Sound Cards [Solved] Recommend me a sound card
Best answer from SAAIELLO.
Could anyone recommend me the cheapest decent soundcard there is? I'm about to build a new rig and this is the last piece of the puzzle that I need, however I know little to nothing about soundcards. I'm not to big on spending alot as I just need it for decent game quality sound and ventrilo/skype etc.
thanks-
Reply to allkindsoftime
I would suggest to you to try the onboard out first. For 99% of people onboard sound is all you will ever need.
I f I were to suggest a card though I would not really get anything cheaper then this.
ASUS Xonar DX $89.99 - 69.99 after rebate which is a pretty good deal.
http://www.newegg.com/Product/Prod [...] 6829132006
Reply to SAAIELLO
I looked at the main website of my mobo and didnt see anything about onboard sound however, asus sabertooth x58
Best answer
Onboard Audio
Audio Chipset
RealtekĀ® ALC892 8-Channel High Definition Audio CODEC
ASUS Noise Filter
Supports 192khz/24bit BD Lossless Sound
Supports Jack-Detection, Multi-Streaming, Front Panel Jack-Retasking
Optical S/PDIF Out port at back I/O
Thats in the motherboard specs. All modern motherboards come with some sort of soundcard either onboard or some motherboard manufacturers will give an expansion PCI E card. The realtek should be fine for what you described you want it doesn't sound like you an audiophile or anything since you are asking for the cheapest solution.
So try the onboard out I bet you will be more then satisfied with it onboard sound has come a long way in the past 5 years.
Message quoted 1 times
Message edited by SAAIELLO on 02-03-2011 at 04:46:05 PM
Reply to SAAIELLO
SAAIELLO wrote :
Onboard Audio
Audio Chipset
ASUS Noise Filter
Wow cant believe I missed that haha im such a retard. Anyways thanks for the input its good to know I can save some money on this part!
No problem Good Luck with your build.
Reply to SAAIELLO
There are 1683 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 2 hours ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
