Hi all,
So I've just got a new computer (3rd gen i7 3770 8gb ram) and surprisingly it came with a 32GB SSD drive. After realising very quickly that I absolutely hated windows 8 I've reverted back to windows 7 64b.
However, my question is how do I use this SSD drive?
My first instinct was to install the OS on it, put the program's on a 500gb drive I have in the PC and keep all my personal files on another 2tb drive - also inside the pc. But after doing this (changing the temp folder, and the desktop location and the my documents etc.) I very quickly filled ths drive up... Within a matter of hours....
I'm thinking that this isn't the way forward. How would you recommend I use this 32gb SSD drive? I need a SIMPLE solution... I reading things about using it as a cache for another HDD, but it's all looking rather complicated...
Could somebody help? I'd like to get it right from the word go....
Thanks,
Harry
Thanks,
Harry
