Hi Everybody,
I have a computer with Pentium-4 3.06 GHZ processor. I have been using it for like 4 years and it never gave any problem. However, recently, while working on it, it turned-off by itself. I googled for the problem and found out that it could happen when the CPU gets overheated. Anyway, I downloaded and installed Motherboard Monitor 5 to view the CPU temperature. Now, it shows the CPU temperature between 79 C and 81 C (Celsius). I also checked it in BIOS and it shows the same temperature.
To bring down the temperature I opened up the chassis and cleaned the dust from the heat sink and motherboard. However, still the CPU temperature has not come down. I also left the chassis open for air circulation but still the temperature is same.
I want to ask:
Is this temperature (79C-81C) normal for P4 3.06 GHZ CPU? Can this CPU bear this much temperature? What is the maximum temperature that this CPU can bear? and If this much temperature is not normal then what should I do about it? I mean what can be the actual problem (because keeping the chassis open also does not lower its temperature)?
Please help me solve this problem!
Cheers!
I want to ask:
Cheers!
