Hi all,
I read the forums on here all the time, but this is my first time posting, so please, be gentle!! I'm building a HTPC and thought I'd pick your collective brains. I"ve already got the case and power supply. Here they are:
Case: http://www.ncix.com/products/?sku=41910&vpn=HTPC-8000&manufacture=NMedia%20System
PSU: http://www.ncix.com/products/index.php?sku=21597&vpn=OCZ850GXSSLI&manufacture=OCZ%20Technology&promoid=1259
The case fits a full size motherboard so I have a couple of options and this is where I'd like your input. I can go with a cheap motherboard and cpu and then get a decent graphics card or I could go a little overkill and get a decent motherboard and cpu and use the onboard video. For the cheap motherboard, I was thinking of going with something that can use the AMD 955 dual core and unlock the 2 "hidden cores" and make it a quad-core, which would be more than enough for what I need this system for, however I also wanted something that would be somewhat "futureproof" if there is such a thing anymore. This is what I was thinking for the more expensive mobo/cpu combo:
GIGABYTE GA-890GPA-UD3H AM3 or ASUS M4A89GTD PRO/USB3 or ASRock 890GX EXTREME4 AM3 AMD 890GX
CPU: AMD Phenom II X6 1055T Thuban 6 Core Processor
Ram: Patriot G Series ‘Sector 5’ Edition 8GB
Bluray Reader/DVD writer combo drive (don't plan on burning blurays at this point)
2 * 2tb drives
I know this is overkill, but the mobo's have an onboard ATI 4290 which I hope would play my movies, though I'm not sure as I have some .mkv files that are over 10 GB each and have DTS encoded sound. If the onboard 4290 is enough then I wouldn't have to buy a gpu for the above, thus keeping the heat down inside the case and improving airflow. This will be outputting over hdmi to my 47" TV through my av receiver. I should also mention that I will have 4 hard drives to put in this so I need a board that has at least 5 sata ports. The nice thing with the above boards is that they have the new sata 6gb/s and USB 3.0. I don't plan on doing any gaming with this, but you never know what I may want to do in the future.
Basically it comes down to skimping on the mobo and cpu and spending money on the gpu or spending the money on a good mobo and cpu and hope and pray that the onboard gpu is good enough for hd playback of large files. I can always add a gpu later I suppose if need be, but I'm already going to be over-budget on this.
Anyhow, I'd just thought I'd pick your brain to see what you think. I should also mention that I won't be buying this all at once, but a piece or two at a time when I can (or when the wife lets go of the purse strings, LOL).
Thanks,
Bill
2 * 2tb drives
Thanks,
Bill
