Hello,
My old sound card no longer works, and I've been using onboard sound in the meantime, but I think I'm ready to shell out for a new sound card. I primarily use my computer for games, but I also listen to music, so it would be nice to get a card that's good for both of those. I'm running Windows 7 64-bit, and I currently use a Razer Mako 2.1 speaker set or headphones. So I don't have surround speakers, but I suppose it would be good to be able to use some in the future if I decide I want them.
So far, I'm considering a few cards:
1) Creative X-fi Titanium Fatal1ty Professional.
This generally gets good reviews, and I can find one for about $100 which is a nice price. But I've heard that the drivers can be very buggy, especially for Win 7 64-bit, which is what I'm running. I've also heard they don't work well for 2.1 speaker systems, which would be a big problem for me. Anyone know if that's true?
2) HT Omega Claro
This also get good reviews, although it costs more than the Creative card. The only real concern I have with this card is whether it's as good for games as the Creative card. I know that Creative has a lot of proprietary stuff like EAX that might only work with one of their cards. Can anyone tell me how well this does for gaming?
3) HT Omega Claro Plus+
Also gets great reviews. Slightly more expensive than the Claro. Apparently the main difference is a higher quality op-amp. Anyone know how much difference this makes? Is it worth the (small) extra cost?
4) HT Omega eClaro
I don't know much about this one, except that it's PCI-E instead of PCI. Is there really an advantage to a PCI-E sound card? I feel like a standard PCI card would fit better on my motherboard, and wouldn't get too close to my graphics card, but if there's a reason to get this over the others, I'd like to know what it is.
5) Asus Xonar
I don't know much about this line of cards either. I've heard they sound good, but I've also heard that Asus hasn't been so great with driver support. Anyone want to chime in on these? If so, which model do you recommend?
Thanks in advance for any advice!
My PC specs in case anyone needs them:
Mobo: ASUS P7P55D-E Pro
Processor: Intel Core i5 760
PSU: XFX 750 Watt
Memory: 2x 2gb GSkill ECO
Graphics: XFX HD5870 1gb
2) HT Omega Claro
4) HT Omega eClaro
5) Asus Xonar
PSU: XFX 750 Watt
