Can you please review my build before I purchase? (i7 machine)
So it is has been a few years since I have kept up on the latest hardware, my last build was 2006 and is still working well for what it is. I need something more powerful though since I use this machine not just for fun but also make my living on it. I have Photoshop, Illustrator or Lightroom running all the time for work (graphic design and photography). I also like to watch videos and play games (not a heavy gamer and have been out of that loop for awhile too - hoping to get back in).
I have spent the better part of a week reading up on the latest hardware and think I came up with a build that will be really good, fast, last me a long time and fun :) I know it is impossible to build a machine that will be top of the line for many years, I am just looking to build some very powerful that will be top of the line for what I need it to be for a a few years (4-5 ideally).
So now onto the parts.
I was looking to stay under 1500 and was able to with this (about $1400 after rebates). I am going to be giving my current machine to a family member so I was unable to save any parts except the DVD burner, Network Card and Sound Card. I am going to run Windows 7 64-Bit (already purchased).
Also of note, I will NOT be over clocking anything and I WILL be using the stock fan from the processor.
CASE
Antec P183
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129061
Used the previous model in my previous build and really liked it, so decided to stick with what I know and like
POWER SUPPLY
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
PROCESSOR
Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W
Quad-Core Processor BX80601950
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
MOTHERBOARD
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
MEMORY
(2 SETS, 12 GIGS TOTAL)
Crucial Ballistix 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148278
12 may be more than I need right now, but would rather buy it now then upgrading down the road. I have already budgeted for this amount of money to spend.
GRAPHICS CARD
EVGA 01G-P3-1465-AR GeForce GTX 465 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130555
Seems to be a very good card from what I have read and reviews. Need input on this though.
HARD DRIVE (SSD FOR OS AND SOFTWARE)
G.SKILL Phoenix Pro Series FM-25S2S-120GBP2 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231378
HARD DRIVE (STORAGE)
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
One last question: Are there any cables, adapter, etc I will need to complete this build? Will I need anything for the hard drives, case or motherboard that do not come already? This is where my not being up on all of this is not helping so hoping you can. Would hate to find out after unboxing everything that I need to order something else.
THANK YOU FOR ANY HELP YOU CAN GIVE ME! HOPING TO HIT ORDER THIS WEEKEND BUT AFRAID UNTIL I GET SOME FEEDBACK!! :-)
50 answers Last reply
More about review build purchase machine
  1. whats your monitor resolution?
    Running dual monitors. My main monitor is 1920x1200, the secondary is 1280x1024. I *may* upgrade the main soon but still a few months away at least.
    May I ask why, is there a problem with something I picked in regards to that?
  3. You don't need 12 gigs of ram....
    I'd get G.skill RAM... http://www.newegg.com/Product/Product.aspx?Item=N82E16820231335 6 gigs....
    another GPU if you can fit it, going higher then 1920X1200.... with one gpu isn't gunna end up well
    Another thing, if you want this to last a while I'd spend some money on a larger PSU, you can upgrade grpahic cards, and it allows you to have it for another build, when the time comes.
  4. ^^ Specifically the gtx 465 isn't that great of a card. A single 460 would be better.
    2xGTX 460 or 2x68xx would probably perform better.
    maybe even the 5870 Eyfinity 6 edition.
  5. ^ yeah.... +1
    Currently when I run Lightroom on dual monitors on my current machine (4 gigs of ram) it slows down a ton, so thought the extra would help. Would it be a help at all or just completely not needed and will show no improvement?
    Why is that, asking because I honestly do not know and would like to learn while I can. The specs of this card say it goes up to 2560 x 1600 and handles dual monitors. My current monitor is great and as a photographer that is what I need, so unless something happens I am not looking to change right now anyway.
    Any suggestion on how much larger I should go?
    If I would to go with just a single card what would you suggest then? Keep in mind I am not a heavy gamer at all and while I do want to play some now it will not be what the machine is always going to be used for. Probably a bit of Call of Duty and the like here and there.
  8. oh, if cod is all your going to play, you can get away with a 5770.....(unless you are hitting 2560X1600...)
    Why is that, asking because I honestly do not know and would like to learn while I can. The specs of this card say it goes up to 2560 x 1600 and handles dual monitors. My current monitor is great and as a photographer that is what I need, so unless something happens I am not looking to change right now anyway. [.quote] it will have low FPS...
    750 minimum, any higher is your choice...
    the i7 can handle alot, I dunno your current specs, so I can't comment.
  9. the specs say 2560 x 1600, but it never says if thats a single card. mainly you'd need a second card for gaming at that high of a resolution w/dual monitors in general.
    and im just guesstimating, but atleast one like this you give you room to expand vv
    it's also 80 Plis GOLD certified (saves you money :)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139016
  10. So for a graphics card would this be the choice if I was going to only have one and staying at 1920x1200 on my main monitor? Gaming would only be on the main monitor anyway.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150447
    If there is a better card I should get I would love to know. Thanks for all the help so far!
  11. the specs say 2560 x 1600, but it never says if thats a single card. +1
    and for Rendering at that res, and stuff like that.... also displaying pictures
    Edit for not paying attention and posting my post half finished.... fail
    I'm thinking the 6870 or GTX 460 would do you fine
    if you were to use multiple cards then
    Sapphire 5770 Flex in CrossFire
  13. Quote:
    +1, it seems you steal everything I was going to say.
  14. Looks like this has the better reviews (GTX 460) but there are a couple of different versions listed. Should I go for this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130567
    Planning on the 470 now after reading reviews and other comments. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550
    Also if I could ask one last question of you guys. Regarding what I asked earlier about needing anything else (cables, adapters, ect) is there anything I should plan on ordering now for any part of the build that I may not be familiar with? Not over clocking so I am assuming the fan that comes with the processor is enough and the fans that come with the case should be fine...correct?
    Graphic design and rendering can take advantage of the extra RAM. Adam, I suggest two sets of this Corsair RAM. Runs 7-7-7-20 instead of 7-7-7-24, and it's cheaper.
    I'm assuming you won't be using your second monitor while gaming? One graphics card would be fine, but I also don't recommend the GTX 465. For graphics design, I usually recommend Nvidia cards, but for gaming, I recommend ATI/AMD. In your case, I'd recommend Nvidia, but know that you'll be spending more to get address both uses. So deciding between the GTX 460 and GTX 470 (really your only options, IMO) depends on what games you'll be playing. Remember that you can upgrade in the future and run SLI cards. If just Call of Duty and the like, a 460 1GB will probably be sufficient. I'm assuming you'd only actually be gaming on the main monitor?
    Oh, more information - great! Very glad I decided to ask for help tonight, you guys are all great :)
    Second monitor will not be used for gaming - it is a lower end monitor I use when working for design stuff only. I mentioned in my previous post that from reviews the GTX 460 looked like a good option - just wast not sure I picked out the correct version (Newegg shows a couple versions). Forget that, decided to go with the 470 I think now http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550
    Regarding the RAM, appreciate that tip. I don't mind paying the extra for the crucial if it is a better product (I have always used crucial in the past so I immediately went to them). If the one you suggested will perform better than I will gladly switch to that.
    Thanks!
    haha yeah (:
  18. Quote:
    haha yeah (:
    scene stealer =p
    Thanks!
    That GTX 460 looks like a great choice.
    Corsair actually has a slightly better name in the industry, but it's like comparing Toyota and Honda; there really isn't much of a difference in terms of quality.
    My last suggestion -- a quality 550W PSU can handle SLI 460s (at max load your system won't draw more than 450W), so I suggest this Antec. It's based on Seasonic's M12D design, so it'd one of the best PSUs on the market. Blargh nvm if you're going with the 470.
    Thanks!
    I dont recommend a 470 unless its a retail card due to poor cooling and power management
    the reference cards suck a** :p
  21. Okay, so based on the last two comments back to the GTX 460 :)
    Is there anything I am missing in regards to cables, adapters, etc that I will need to complete this. I know I asked this already but did not get an answer and just want to be sure. I built my last machine but had someone tell me what to buy so this is new to me.
  22. maybe SATA cables... most of the things sohuld come with them... OEM I think sometimes leaves them out...
  23. as long as nothing is OEM then everything should come with the cables. :D
  24. Which 460 card?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130562
    $140 after rebate
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130568
    $200 after rebate
    Would I notice a difference if I spend the extra - no problem doing it if it is worth it.
    Oi, stop changing your mind! :pt1cable: If you go with a 460, you'd want a 550W; if you go with a 470, you'd want a 750W. This is assuming that you'd consider SLI in the future and that you buy a quality PSU.
    Um, you may need to buy an HDMI cable, if your monitor supports HDMI input.
    grrr... you beat me to the OEM part. >.<
  27. adam533 said:
    Which 460 card?
    $140 after rebate
    $200 after rebate
    Get the stock clocked EVGA 1GB version (your res will benefit from the extra graphics memory).
    I recommend this over the SC version because you can OC the card yourself and the stock clocked one is not based on the reference design, which means it'll run cooler. Plus, at $20 less, you still get a free game.
  28. http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333&cm_re=460-_-14-125-333-_-Product
    ^^ That one. Gigabyte is just as good as EVGA but not overpriced.
    also make sure its a 1gb card
  29. I feel like I hit the jackpot tonight with all the great help I got in this thread (and so fast!) Thanks everybody.
    So after your comments here is the final list if you can give it a quick once over. Motherboard and SSD seem like good picks?
    Thanks again!! I am getting excited to order this now.
    Changes from original post shown in BOLD
    CASE
    Antec P183
    http://www.newegg.com/Product/Prod [...] 6811129061
    POWER SUPPLY
    Antec TruePower New TP-650 650W
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021
    PROCESSOR
    http://www.newegg.com/Product/Prod [...] 6819115211
    MOTHERBOARD
    http://www.newegg.com/Product/Prod [...] 6813128423
    MEMORY
    CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145250
    GRAPHICS CARD
    EVGA 01G-P3-1370-TR GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130570
    http://www.newegg.com/Product/Prod [...] 6820231378
    http://www.newegg.com/Product/Prod [...] 6822152185
  30. looks great :) Happy buying/building :D
  31. One thing you do want to do before buying is to check for combos, like this one. $15 saved on parts you had picked out already! I'm sure there are others like it; do look around.
    Awesome, will do that tonight. Thanks for the tip!
    Again to everybody who responded, you guys rock! Thanks so much for sharing your knowledge, it really saved me on this!!!
  33. It is our pleasure, if you ever need anything else, we are here... =D
  34. btw, I should've said this earlier, but a SSD from Mushkin is better.... They do great SSDs...
    Great, only $5 more than the one I had picked out too. Looking at it now and will replace with what I had.
    Thanks again, I may be back when it comes time to put all this together if I run into trouble in two weeks. Away on work all next week so I have something to look forward to when I return now - lots of UPS packages lol
  36. yeah, your UPS guy is gunna hate you after this... lol =p
    The local people near me do... I get about 50000000 packages a day.... stuff I ordered, stuff my friends are trying to prank me with, work, ect...
    you get fifty million packages a day?
    thats... THATS OVER 9000!
  38. Quote:
    dude I think you are my clone....
    I am expecting a lot to be delivered, but not that many LOL
    Hopefully they all come the same day because I need UPS to hold them at their central office, and they can only do that after one failed delivery. Would feel bad if he had to do that multiple times :)
  40. yeah, I feel the same, I THINK you can like go in and say, I got a bunch of packages coming, can I pre-sign.....
  41. im almost positive if you buy all the stuff at the same time newegg sends it withing 1-2 business days.
  42. yeah, I couldn't see them going, "hey, let's sned his mobo out tuesday the GPU monday, and the rest a week from now" ^^
  43. i could see amazon doing that..
    :OOOOOO BURNNNN hehe.
  44. As far as I am concerned, they have a week to get it to me - as long as the parts are there for me to put together next Monday I will be thrilled :)
  45. yeah, Goodluck! and Happy gamin'/not gaming...
  46. Cpu:AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
    Motherboard:ASUS Crosshair IV Formula AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131644
    Memory:Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model 996829
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226127
    Gpu:XFX HD-687A-ZNBC Radeon HD 6870 Black Edition 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready Video Card with Eyefinity
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150507
    HDD:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    Psu:XFX P1-650X-CAG9 650W ATX12V 2.2 / ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207002
    Case:COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
  47. You must use the 64-bit versions of LR and Windows to need 12GB of RAM. If you use the 32-bit version, LR will only be able to use 2GB of RAM and will still cache data to the hard drive, regardless of how much RAM you have.
  48. Quote:
    I got four six emails from you posting this exact post on different threads, and I'm sure there are more. Do mods handle this stuff?
  49. blackjellognomes said:
    I got four emails from you posting this exact post on different threads, and I'm sure there are more. Do mods handle this stuff?
    Same here.
    he uses the same two builds for everything.
    i don't even think he reads what the OP says.
Build Systems
