Hey, I am asking you guys what you think the best brand is for the HD 5970? There are many to choose from, and I just don't know which provides the most reliability/customer service/performance.
These are the ones I'm looking at from Newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131324&cm_re=5970-_-14-131-324-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125303&cm_re=5970-_-14-125-303-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121357&cm_re=5970-_-14-121-357-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150460&cm_re=5970-_-14-150-460-_-Product
Any input from experience with any of those cards or reviews or anything would be greatly appreciated. Thanks in advance =)
