Computer usb not found problems and solutions
Hello sir,
im using mercury kob p4m266 nfdsmx
motherboard, its usb not found the deivecs,im reinstal the driver but the same problem is there.im add a adistional usb card on PSI slot its working properly.any boby help me to solve the problem.
Best regardzz
sajan
2 answers Last reply
More about computer found problems solutions
  1. What operating system are you using? And, are you sure the USB ports are enabled in the BIOS? Last, is your problem with the front panel USB ports or the back (I/O) ports, or both? Please clarify.
  2. Yah, more info needed.
    I'd always start by unplugging all usb devices then uninstalling all usb options in device manager and reboot.
CPUs Mercury Computers USB Motherboards
