New Gaming PC built NEED HELP
Hello all! :hello: :hello: :)
Is this a good built for mid - high end gaming Pc (would like to have Highest graphics for games with good Framerate)
the pc will mostly be used for black ops, starcraft 2, World of warcraft ect... and web surfing.
Budget - $1000 - 1350 au
* AMD Phenom II x4 965 BE - $ 159 au
* Gigabyte GA-890FXA-UD5 - $ 225 au
* 3.5" HDD SATA-300 1.5TB
32Mb/7200rpm Seagate - $ 85 au
* 4Gb (2x2GB) PC3-12800 (How many Gbs of ram should I get and whats teh different between 1600MHz vs 2000MHz)
(1600MHz) DIMM Kit - $ 89 au
* 5.25" DVD Burner/Rw - $ 22 au
SATA LG GH22-NS50 LGE 22x (oem) Black
* Radeon HD 6850 - $ 225 au ( Should I get crossfire x2 for these Radeons or is one GPU good)
* Gaming Case Apache - $ 65 au
H-21BK (Huge Fan on the side) No PSU
* Power Supply 650w Power case - $ 59 au
(Peak Power 650w/True Power 400W)
* Second Ram site description - $ 39
http://www.elixir memory.com/products/file/Elixir-DDR3-1G-A-UDIMM-R10-HS.PDF
Total cost - $ 968 au
cash left - $ 382 au
Thanks! :bounce:
14 answers Last reply
More about gaming built help
  1. Hello, it appears that you are in Australia. Where are you buying from? Where do you live? You may be able to find a place that offers pickup, umart and gocomp in Brisbane offer pickup.
    Your base build seems pretty solid and the prices seem good.
    That motherboard is high end and not really required. Pretty much it just goes like this, 880G for single CF, 890GX for dual CF and 890FX for more then 2 cards. So really you only need an 890GX board.
    You also have not included brands, models names, etc for RAM and HDD.
    Ahh I just realised your PSU, that is not good. Originally I thought it was a Antec TruePower. You should NEVER scimp on the PSU, a bad PSU dying can mean the death of all your components. Look for Antec and Corsair PSUs at around 650W.
    Also I woul prefer a name brand case like a Coolermaster HAF922 or Antec 902.
    Thanks for Quick reply
    - I'm buying from a place called It estate at North rock NSW and J & W in sydney.
    - I live in Sydney so no Brisbane for me.
    The ram is a Patroit and Elixir.
    I can change the PSU to a 600W Coolermaster plus.
    The HDD is a Seagate.
    I can change the case to a Coolermaster Cm scout.
  3. Also I can get a 890Gx board =P
  4. Oh oh if $$ is an object i would really
    Hit a decent 80+ 650Watter (yours sound like the not so good Extreme Power series CM)
    790X/790GX if u want CF but no need USB/SATA 3.0
    955BE
    955BE
    ok thanks
    I can get a 700w Coolermaster Extreme plus
    also the 965 BE is only $ 4 more then the 955 at the shop, and for the Motherboard I'm finding it hard to find a good shop for motherboards?
  6. I would generally stay away from the coolermaster PSUs. Though that may be one of their good ones, is it this one?:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171032
    Heres a good 890GX motherboard:
    http://www.megabuy.com.au/asus-m4a89gtd-pro-p215121.html
    This is the Web site for the Extreme coolermaster PSU - http://www.coolermaster-usa.com/product.php?product_id=2991
    Also does can i pick up the items at Megabuy
  8. Also I can onlty do places that offer pick up
  9. Oh ok, no you can't pickup from megabuy. You should be able to find a 890GX board at one of the stores your looking at. Link me to the stores and I'll have a look.
    The Extreme Power Plus line of PSUs seem to be utter crap. What other choices do you have? Link to the shop?
    Also instead of posting twice in a row use the edit feature.
    Ok, the Stores are It estate ( http://www.itestate.com.au ) and J & W ( http://www.jw.com.au )
    Also thanks for the info on the PSU, I looked around and saw a different PSU Huntkey 700W
    ( http://www.itestate.com.au/pages/product/pdt_product_detail.faces?BeanName=productDetailAction&pcode=08264 )
    Oh, another thing what's better for ram 1333 MHz, 1600 MHz or 2000 MHz and how many GB's of it?
    Sorry I'm new didn't know about edit feature :)
  11. Hey, Huntkey is another brand to stay away from. Unless there are reviews on a so-so branded PSU it is not a good risk.
    The Corsair TX-650 seems like the best buy at $145 though this is overpriced as they can be bought for $115.
    http://www.jw.com.au/corsair-650w-tx-650-atx-power-supply-p-431
    High clocked RAM is mainly for OCing but since you have a BE CPU this doesn't count so 1333MHz will be fine.
  12. Thank you soooo much for spending your time to help!! =D
  13. Glad I could help, I forgot to look for a motherboard for you. Did you find one?
  14. Hello all, sorry for opening an old thread but I want to thank everyone for the help on my homemade PC.
    The specs of the PC turned out to be this.
    - Phenom II x4 965 Black edition
    - Gigabyte GA-870A-UD3 Motherboard
    - Kingston GB kit 1333 DDR3
    - Thermaltake V6 Case Black Edition ( messed up was supposed to buy v9, so be it )
    - Sata Samsung 3.5" 1TB
    - LG Sata Black DVD RW
    - Seasonic 620Watt bronze PSU
    - Gigabyte GB 5870 VGA Card
    - Total build price $ 1156 Aus (includes GST)
    Thats my current build and I'm loving it!
    Soon to be upgrades
    - Another Kingston 4GB kit
    - 21 - 23" LED Monitor
    THANKS AGAIN ON THE HELP!
New Build Gaming Systems Product
