Hello, I was wondering if this a is a good built playing black ops, Starcraft 2 and other FPS's at full settings with around 40+ frame rate.
Sites Buying from http://www.itestate.com.au and http://www.jw.com.au
Playing at 1440 x 900 pixel resolution
- $1200-1350 no more
CPU - AMD Phenom II x4 965 BE - $ 159 au
Motherboard - Undecided (would like to have 2x ATI CrossfireX support)
Hard drive - 3.5" HDD SATA-300 1.5TB 32Mb/7200rpm Seagate - $ 85 au
Ram - 4Gb (2x2GB) PC3-12800 (1600MHz) DIMM Kit Patroit - $ 89 au
} Should I get 4GB's or 6GB's
Ram - Second Ram - site description - $ 39
http://www.elixir memory.com/products/file/Elixir-DDR3-1G-A-UDIMM-R10-HS.PDF
Optical drive - 5.25" DVD Burner/Rw SATA LG GH22-NS50 LGE 22x (oem) Black - $ 22 au
Graphics card - Video Card (ATI) PCI-e 6850 1GB Gigabyte GV-R685D5-1GD (775/4000MHz) - $ 225 au
Case - Gaming Case Coolermaster CM SCOUT - $ 125 au
PSU - Power Supply 700w Huntkey (APFC/14Cm Fan)
THANK YOU
THANK YOU
