Hi,
I recently installed a 256 GB SSD for my OS as well as a 6-bay 2.5-inch disk bay so now have the original 1 TB hard disk for storage, the 256GB SSD for the OS plus five other standard 2.5 inch disks of varying sizes.
I switched to AHCI with the registry settings and in the BIOS and everything works fine.
However, I live in rural Laos and we have a LOT of power cuts and my UPS doesn't keep the PC going if the power suddenly goes, although it strangely does when there's a brown out long enough for it to beep down to switching off point, if you see what I mean.
Anyway, when the power comes back on and I boot up the PC again it says it has reset BIOS settings to default due to an error and it switches to RAID so I have to go into the BIOS and switch it back to AHCI. Is there anything I can do to stop this?
Also, is there any general advice on what I can do to minimise problems caused by power cuts since they are unavoidable here? I can't buy a quality UPS since they don't exist in the shops here. We only get cheap Chinese copies!
OS: Windows 8
CPU: i5 650 @ 3.20 GHz
RAM: 16GB DDR3
Thanks in advance for any help.
Barns
OS: Windows 8
RAM: 16GB DDR3
Barns
