Solved
Help on i7 build
Last response: in Systems
Approximate Purchase Date: In about 2 weeks
Budget Range: $1000 (reusing a couple of parts)
System Usage from Most to Least Important: Gaming
Parts Not Required: Case(Antec 900), PSU(Corsair 750w), DVD Burner, Monitor, OS, keyboard, mouse, speakers.
Preferred Website(s) for Parts: Newegg
Country of Origin: California
Parts Preferences: I7 950, Gtx 470
Overclocking: Most likely
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1200
More about : build
Best solution
Related ressources
^ Even I feel the Sandybridge would achieve high overclocks because of the 32nm Manufacturing Tech and also the new architecture, but there is a catch though, you would need the K series CPUs so that you can overclock as now the BCLK is attached to the PCIe bus hence not easy to overclock by increasing the BCLK, that is the reason why he has a K series I guess...
You might try pricing a similar machine with an i5-750 or so. Not long ago this would save you $200 or so, I don't know what it's like right now. Even the lowly i5-750 will overclock very well and make a darned fast machine. With the savings you could put even more into your GPU.
i5 760 2.8 Ghz - $209
Asus p7p55d-e Pro - $180
Mushkin Enhanced Blackline 4GB (2x2GB) DDR3 1600 Cas 7 - $80
OCZ Vertex 2 60GB 2.5" SSD - $120 after MIR
GIGABYTE Super Overclock Series GV-N470SO-13I GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready Video Card - $310 (with free game)
Samsung Spinpoint F3 1TB - $70
Hyper 212 + and Shin-Etsu - $30
total= $999 before combos.
Ask the community
