This is what I've got and assembled.
Item: Corsair 650W TX Series PSU - 120mm Fan, 80+% Efficiency, Single +12V Rail - Qty: 1
Item: EXTRA VALUE 4GB (2x2GB) DDR3 1333MHz Memory Kit 1.5V CL9 - Qty: 1
Item: Inno3D 9800GT Esave Edition 512MB GDDR3 DVI VGA HDMI Out PCI-E Graphics Card - Qty: 1
Item: Intel i5 760 2.8GHz Socket 1156 8MB L3 Cache Retail Boxed Processor - Qty: 1
Item: Gigabyte GA-H55M-UD2H H55 Socket 1156 VGA DVI HDMI Out 8 CHannel Audio MATX Motherboard - Qty: 1
Item: Antec 902 Nine Hundred Two Black ATX Case - No PSU - Qty: 1
Item: Corsair CWCH50-1 Cooling Hydro Series H50 High-performance CPU Cooler supports LGA1156 LGA775 LGA1366 AM2 and AM3 processors - Qty: 1
One problem is that it won't recognise this HDD which I transferred from my old comp (the one I'm using now) but I have a spare HDD which I'm going to try and format and put windows xp on for now when I can find the disc.
But the main problem is that when I went into the bios it said my CPU temp is 88c. To me it seems the fan is working fine but according to the data, it isn't. Can anyone help?
