External Enclosure + Adv Format - power draw & allocation unit size?
February 27, 2013 7:40:02 PM
3 questions about external enclosure & advanced format drives:
I just got a 750 GB WD Black 2.5" (mobile) -WD7500BPKT- and I want to use it in this external USB3 enclosure -http://tinyurl.com/c5qbuzl. I'm wondering if I can use a standard USB3 cable, or if additional power is needed. The enclosure comes with a "Y-cable", which is double-USB to a mini-USB.
The enclosure has a note: "CAUTION!! When using USB 3.0 interface mode, external power is needed when HDD consumes power over 900mA".
The HD's spec sheet lists a "5VDC ±10% (A, peak)" of 1.15.
WD7500BPKT specs: http://www.wdc.com/wdproducts/library/SpecSheet/ENG/287...
Is this the power spec I'm looking for? Does this mean it draws 1150mA, exceeding the capabilities of a single USB3 cable? If so, can I use the included Y-cable, or must I get the power supply accessory from the maker of the enclosure?
> Question 2: This is an Advanced Format drive (http://www.wdc.com/wdproducts/library/WhitePapers/ENG/2...). I'm wondering if I need to run the special alignment software, for compatibility between machines (will be using with clients). For example, if I format it on my Win 7 machine (AF-ready), will it be usable on a client's Win XP machine?
> Question 3: Will alternative allocation unit sizes work with an AF drive, or must I stick to 4096? I believe there is a difference between sector & cluster size, & I'm not sure whether this is even relevant. I personally will stick with 4096 for now, but I sometimes assist folks with workstation setups, who might be interested in a larger allocation unit size.
Thanks!
