I'm looking to build a gaming PC and have most of the parts that I would like. Since this is such a big purchase, I want to double check and make sure everything looks good. Any recommendations or suggestions will be appreciated
Approximate Purchase Date: within the next month Nov 16, 2010 - Dec 31, 2010
Budget Range: $1500-$2000
System Usage from Most to Least Important: Gaming -> Media -> Internet -> Work
Parts Not Required: Keyboard, Mouse, Monitor, Speakers, Harddrive
Preferred Website(s) for Parts: newegg.com -> amazon.com -> buy.com
Country of Origin: USA
Parts Preferences, by brand or type: Intel CPU, Nvidia video card
Overclocking: Maybe
SLI or Crossfire: Yes
Monitor Resolution: 920x1080 or 1920x1200
Additional Comments: Looking for a cool running and quiet system. Easy to possibly upgrade/overclock in the future. Making sure that all parts are compatible with each other.
Parts That I Own:
-ASUS MS238H 23" LED
-Logitech 2.1 Z-2300 THX Certified
-OCZ Vertex 2 90GB 2.5" SSD
Parts Researched:
-LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM = $19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
-COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case = $139.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
-2x EVGA 012-P3-1472-AR GeForce GTX 470 (Fermi) SuperClocked 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card = $539.98 ($269.99 each)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130549
-Creative 70SB073A00000 7.1 Channels 24-bit 96KHz PCI Interface Sound Blaster X-Fi XtremeGamer = $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102006
-CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply = $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
-CZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3P1600C6LV6GK = $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227573
-ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard = $284.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
-Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950 = $294.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Overclocking: Maybe
Parts That I Own:
Parts Researched:
