Hi there, I'm a complete noob to this, so bare with me here
I'm looking to make me a computer from scratch, this will be my first time, I'm a bit scared because of buying the right parts, below is my SO FAR list of what items I'm getting to build my computer
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128437&cm_re=ga-h55_atx-_-13-128-437-_-Product
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104227
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115221
Graphics Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814141118&Tpk=biostar%20radeon%20hd%205570
Now my PC case has a 480W included with it
1st question
Will this all be supported?
2nd question
do you think I need more Watts than 480?
3rd question
what optical & hard drive should I get?
4th question
if I get a hard drive that is a SATA 3.0Ghz, it usually is Bare bone, what cables do I need with it to properly install?
I would really appreciate any help
thanks
Motherboard
RAM
CPU
Graphics Card
1st question
2nd question
3rd question
4th question
thanks
