System does not prompt for username and password while connecting to wireless ne
Hello,
When I trying to connect to secured wireless network from my netbook, the system (Win XP) does not prompt for any user name and password or security key, but just tryes automatically connect to the network. And since the network is secured it cannot connect properly. Tell me please, how to turn off this automatically connection option and make the system asking me for password that I could input it?
Thanks a lot,
Alex.
1 answer Last reply
More about system prompt username password connecting wireless
  1. Suggest you simply disable or delete that connection.
Configuration Wireless Connection Wireless Network Windows XP Wireless Networking
