Sign-in / Sign-up
Help with choosing psu and gpu
  • New Build
  • GPUs
  • Call of Duty
  • Systems
  • Product
Last response: in Systems
November 18, 2010 10:52:25 AM
hello everyone,
i have this computer
http://www.expertreviews.co.uk/pcs/243867/advent-pdq500...
I was thinking about getting a new psu and gpu fo it, but would this require a new pc case.
And also could anyone help me find a psu and gpu for gaming like call of duty black ops and gta 4.
More about : choosing psu gpu
November 18, 2010 1:08:22 PM
whitebuddha said:
hello everyone,
bsically i need to find out what psu my motherboard supports and what pc case will the psu fit in. thanks in advanced for anyone that replys
November 18, 2010 2:35:15 PM
it says that it's a mid tower, so it should handle any mid-high end graphics card. if you are worried about space, get a gtx 460 1gb ($200- $180 after rebate). its 8.25" long or so when the competition is over 10". ATi alternatives to this card would be a 5830, 5850 or 6850.
for a PSU you could look at this one: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
its a good psu for a mid range system. if you want to find a different one look for 650W or so.
November 18, 2010 2:48:30 PM
The only thing im worried about is finding the right sized psu to fit in that case. If i cant find the right sized psu could i get a pc case with a psu already included.
November 18, 2010 3:31:41 PM
most psu's are the same size, apart for the extended ones... just check and it will fit
November 18, 2010 3:49:37 PM
Get a new computer...
November 18, 2010 4:02:37 PM
yea because i do have money growing out my arse
November 18, 2010 4:07:17 PM
Upgrading your PSU isn't gonna do crap, you'll be wasting money, and if you do get a better GPU, I doubt itll work with whatever mobo you have in a case like that
