Laptop Power Question....
Forum Laptops & Notebooks : General Laptops & Notebooks - Laptop Power Question....
Archived from groups: comp.sys.laptops (More info?)
Found an auction for a Compaq 2108CL which states:
POWER
90W AC adapter (three wire)
Eight-cell Lithium-ion battery
Is this a USA standard power supply the auction company UBid refers to their
faq which has no info..
*********************End Transmission********************************
Send all complaints, requests and/or thanks to count_strad@yahoo.com
ICQ #34907449
Website - http://www.sithicus.org
"Try not, do or do not there is no try" - Yoda(Empire Strikes Back)
Suggestion(s) or comments?
Sponsored Links
> POWER
There are no 'real' standards with respect to laptop power supplies. Each
supply is model specific for the most part. Suggest you access Compaq's web
site and look up the power adaptor for that particular model number.
If the power supply is included in the auction, the spec's mean that it has
a three wire (hot, neutral, ground) input from mains supply, which is
standard all over the world. 90 Watts is the power draw at whatever voltage
to which it is connected. Most laptop supplies are universal, in that they
can be connected to all common world voltages/frequencies with the
appropriate power cord or by adapting the cord supplied. That specification
has been left out of the info you supply.
The battery spec above is just a description of the internal battery.
jak
> to their faq which has no info..
Reply to Anonymous
thanks for the help...
"jakdedert" <jdedert@bellsouth.net> wrote in message
news:%zxKd.551$RJ2.180@bignews6.bellsouth.net...
>> POWER
> web
> has
> voltage
> they
> specification
> jak
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Laptop Power Question....
There are 1208 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
