Yes, I can tell the difference between "shutdown" and "sleep". It shuts down as usual, goes into black screen and just keeps the fans running. They only stopped after i pulled the plug. I updated my BIOS not so long ago, can't be that.
Currently got no idea what it is, but I'm gonna open it up tomorrow and see if it's a loose connection or whatever, you never know.
EDIT: I could hold down the power button till it "really" turned off, including the fans.
