Solved
My PSU is not reporting fan speed anymore
  • Power Supplies
  • Rosewill
  • Green
  • Fan Speed
  • Components
Last response: in Components
February 14, 2011 2:18:51 AM
Hello,
I have a 1 year old rosewill 430 green psu which always reported a fan speed of 825 rpm, but now, it reports 0 in fan speed and n/a in bios...
Alhough it does not report speed, it does move...
Is this a bad sign?
More about : psu reporting fan speed anymore
a b ) Power supply
February 14, 2011 8:35:25 AM
You have a rosewill. It is prob dieing.
Infact the PSU was prob dieing before you even installed it into your computer.
On a more serious note..
Yes your PSU sucks.
No you should not ever buy a rosewill PSU again.
Stick with Seasonic, cosair ect
The thing that probally happened is the onboard speed reader melted... Rosewill does its bet at making things break easily.
m
l
Best solution
a c 243 ) Power supply
February 14, 2011 9:48:50 AM
khmer said:
Hello,
Is this a bad sign?
That power supply doesn't have a fan RPM cable to connect to the motherboard, whatever reading you were getting was false anyway.
February 14, 2011 10:01:39 AM
How did you get a reading for the PSU fan speed anyways? Your computer BIOS cannot read PSU fan speed. Perhaps you meant CPU fan speed?
m
l
February 20, 2011 10:59:12 PM
Best answer selected by khmer.
m
l
