Archived from groups: rec.photo.digital (More info?)
I ordered a second battery for my 20D - a 511A, 7.4V, 1390mAH (non
Canon). I received a 511, 7.2V, 1400mAH. Can this battery be used
without any consequence other than reduced charge life? If so, how much
reduction? If there's not much difference, I'd rather not go through the
hassle of returning it. Thanks.
"pjruiz(nospaam)" <"pjruiz(nospaam)"@charter.net> wrote in message
news:iHaGd.4856$QV5.802@fe06.lga...
> Paul
The older 511 was rated at 1100 mah. You received a 511 that was rated at
1400. Just use it because it is better than the battery you ordered. There
will be no reduction.
Doubt if you would notice the diffence in its use- I use three of them in a
300D, and they are better than the Canon original...
>I ordered a second battery for my 20D - a 511A, 7.4V, 1390mAH (non Canon).
>I received a 511, 7.2V, 1400mAH. Can this battery be used without any
>consequence other than reduced charge life? If so, how much reduction? If
>there's not much difference, I'd rather not go through the hassle of
> Paul
"pjruiz(nospaam)" <"pjruiz(nospaam)"@charter.net> writes:
>But.... the camera came with a 511A rated at 1390 mAH and 7.4V.
And your new battery is rated at 1400 mAh, so it should have slightly
longer operating time. Canon differentiates between the 1100 and 1390
mAh batteries by giving one of them an "A" suffix, but that doesn't
matter - it's the mAh rating that counts.
Also, the battery is two LiIon cells in series. The voltage may range
anywhere from about 7.2 to 8.4 V depending on the state of charge. It
doesn't matter whether the label says 7.2 or 7.4 V.
> much reduction? If there's not much difference, I'd rather not go
> through the hassle of returning it. Thanks.
I bought two
"For BP511 Replacement
Li-ion Battery 7.4V 1800mAh"
From Sterlingtek via Amazon.com
The order was for 1390mAh batteries, but 1800 was what Sterlingtek
delivered. They were $11.99 each, and arrived a week or so after the
order was placed. Shipping and handling was $9.98, pretty much at the
upper limit, my view, but the cost for each battery was $16.98.
When I received them I measured their voltages out of the package:
7.64 and 7.67
I charged them in the
"Canon
COMPACT POWER ADAPTER
CA-PS400"
which is like the regular charger, except it has two receptacles
side-by-side, and an outlet for the power cord allowing use of the
camera in an AC environment.
They charged one after the other, left to right: one light blinked;
changing batteries from one receptacle to the other, the blinking light
did not follow the battery. After charging (and the at-least-an-hour at
no-blink recommended for the second battery; meaning the first battery
got its own charge and the additional time-in-receptacle corresponding
to the charge time for the second battery and its subsequent hour), I
measured their voltages:
8.33 and 8.11, respectively.
news:U6bGd.12600$u31.9088@fe05.lga...
The higher the "mAH" the better...so long as it's still rated 7.4V.
> I bought two
> 7.64 and 7.67
> "Canon
> CA-PS400"
> After five days on the shelf:
> 8.30 and 8.10
> That's it. Science marches on.
Good to hear of other's experience. A lot of the stuff
stated on Li-ion batteries doesn't fit my experience. I
have 3 batteries for my Nikon. The original is 680 mAh and
the two others are 1000 mAh. I know that voltage
measurements don't directly show charge, but voltage is an
indication. Based on voltage measurement, I am unsure if
the Nikon charger will fully charge the the larger capacity
batteries. Today I checked the voltage of the original
Nikon battery which was charged at least 3 weeks ago and it
is 8.29V. One of the 1000 mAh batteries charged nearly 6
weeks ago read 8.00 V. I put it in the charge which went
off in about 15 minutes and the voltage read 8.21. The
battery that had been in the camera also a 1000 mAh battery
was charged and it took 1 hour. It does seem that the
battery charger stops at 1 hour regardless. So after
waiting a bit, I put the battery back in and it quit in
about 10 minutes. The voltage read 8.21.
Now that seems strange. All of the batteries charge in
about 1 hour and then the charger stop. The 680 mAh battery
has a higher voltage than the two 1000 mAh batteries. That
suggest to me that my Nikon charger is time controlled and
just won't fully charge the 1000 mAh batteries.
Does that seem correct or is it just differences in
batteries. Interesting that my one battery has as high
voltage after 3 weeks as yours did after 5 days. Or maybe
our meters aren't that accurate.
I have no question about the mHA rating. The 7.2V rating on the new
battery was what concerned me. The original batt had a 7.4V rating. In
any case, I'm just going to keep it and see what happens.
Re other posters comments: the new batt came up to 7.8V with a 12 hr
charge.
> Paul
Just in case you're still interested in procuring batteries for your
20D, I bought a couple of BP511 type batteries from TigerDirect.com that
are rated to be 7.4V 1500mAh. The batteries are made by Mercury and cost
$19.95/per. I've been using them for some time now and they appear work
as well as Canon batteries.
I also bought BP511 type batteries from B&H made by CTA. These batteries
are also rated to be 7.4V 1500mAh. I think these batteries cost about
$35/per. I haven't encountered any problems when using these batteries.
For readers who have the 1D MK II camera, I bought a couple of Canon
NP-E3 replacement batteries made by CTA from B&H for about $69/per. They
are rated at 12V 220mAh and they work like a charm.
> Paul
It'll be fine. Most of the after-market BP511 batteries are 1400-1500mAH.
The best source for BP511 I've found is:
"http://www.sterlingtek.com/ln03-canon-bp-511-dlc511.html"
> I bought two
Interesting that the same battery is 1500mAH on the SterlingTek web
site, but 1800mAH from SterlingTek via Amazon.com.
In any case, it's gone from Amazon as a new product.
On Wed, 19 Jan 2005 16:54:01 GMT, "Steven M. Scharf"
>> Paul
>$12 for a 1500mAH BP511 equivalent.
WOuld you clarify "best source"? Have you dealt with the supplier and
their batteries or is it just the lowest price you found searching on
line? Thanks.
> line? Thanks.
Yes, I have purchased from this supplier.
One very big advantage to their products is that their supplier's
product at least appears to have implemented the communications between
the Canon charger and the battery, something that is not the case with
many of the low-cost eBay type batteries.
I think that often the capacities that the after-market batteries claim
are overly optimistic.
>> I bought two
I used these Sterlingtek 511s on Sunday, to make about 500 exposures.
Today the camera displays the "full-battery" symbol, and they measure
7.96 and 8.00 volts as compared to 7.64 and 7.67 when they arrived, and
8.33 and 8.11 after charging, just before I posted about them last week.
All number pairs refer to #1 and #2 respectively.
Frank ess
Forecasting is difficult. Particularly about the Future.
-Deepak Gupta
On 19 Jan 2005 11:40:36 -0800, "Scharf-DCA" <scharf@hotmail.com>
>> line? Thanks.
Thank you for clarifying. I was not aware of the "communication"
problems...
I ordered directly from SterlingTek and they shipped 1800mAH ones.
On Wed, 19 Jan 2005 17:27:45 GMT, "Steven M. Scharf"
>> I bought two
