Recommended power supply for a Corsair 600t
Could somebody give me there opinion on which power supply would fit good in "Corsair 600t" case? I am looking for something that has long enough cables so I can route them behind the side panel. Please help if you can. Thank You! :D
2 answers Last reply
More about recommended power supply corsair 600t
  1. Most units will fit just fine in there, a much more important thing to know is what you need it to power and what your budget for the unit is. Whether a unit has long enough cables comes after figuring out what units would be able to power your system.
  2. I actually already have a corsair hx 550 in my older case. I think I will just use that one instead of buying another. It has enough power for I am going to use it for. Thank you very much for your reply. :D
Power Supplies Corsair Components
