Will this build work/ any suggestions need to keep it under 400$
will this build work. and are there any suggestions to improve it.
need to keep it under 400$ btw
AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
Model #:ADX640WFGMBOX
Item #:N82E16819103871
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm ...
Model #:CHALLENGER
Item #:N82E16811147153
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
ASUS M4A78LT-M LE AM3 AMD 780L Micro ATX AMD Motherboard
Model #:M4A78LT-M LE
Item #:N82E16813131619
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131619
GIGABYTE GV-N240D3-1GI GeForce GT 240 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
Model #:GV-N240D3-1GI
Item #:N82E16814125305
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125305
COOLER MASTER Elite 460 RS-460-PSAR-J3 460W ATX12V V2.31 Power Supply
Model #:RS-460-PSAR-J3
Item #:N82E16817171046
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171046
Kingston 2GB 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model KVR1066D3/2GR
Model #:KVR1066D3/2GR
Item #:N82E16820134785
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134785
Recertified: Western Digital Caviar Blue WD2500AAJS-FR 250GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WD2500AAJS-FR
Item #:N82E16822136759
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136759
6 answers Last reply
More about will build work suggestions
  1. Hello grufzar, and Welcome to THW.
    Just a little helpfull advice, not to many people are going to read this and go through all those links, If you can, edit your original post and copy and paste the names of the parts and thier model numbers before each link.
    You'll find you will get alot more help that way. :)
  2. orly ty this is my first build so it all kind of new to me ill edit
  3. Hey its not a problem, we all have to start somewhere right? I'll be back in a while and i can check it out for you.
  4. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  5. yeah, mainly, but it will do other things as well but none as demanding. I'm also wondering if i should drop the quad core for a dual core and get a better mobo.
  6. first, swap wd hard drive for samsung spinpoint...
New Build Systems Product
