Hello everyone. This is my first post. I think it is more than time for me to build myself a new system but have had some restraints because of my finances. I am looking to build a system with an intel motherboard which will last me for quite a while. the 1156 boards seem more in my range. i will be buying the parts over a couple of months as its the only way i can afford to do this. My main question is, can someone recommend a board which has adequate slots, for ram and pci -e slots and what i can use to upgrade i.e. i am looking at an i3 processor now but then an i5 later on or i7. i havent built systems for a while now so im a bit out of the loop and looking for some advice. any help will be greatly appreciated. i can provide more info if need be which will likely be the case.
cheers
cheers
