Solved
How to hook 3 pin fans to power supply?
Last response: in Components
Best solution
andyman30 said:
Ok thanks, and then after I convert this to molex, that will plug into my power supply?
Correct. This particular adapter can either just connect to an available PSU connection, or go in-line with an existing PSU connection (like between the PSU and your DVD drive, hard drive, etc) so you don't have to waste a power supply connection.
Ask the community
