G
Guest
Guest
I just bought a new system.
The specs:
- AMD 1055T x6 core @stock
- MSI 890-FXA
- 2x2 Kingston HyperX 1600 MHz (KHX1600C9D3K2/4GX)
- ThermalTake Toughpower XT 750 Watt PSU
- Sapphire Vapor-x HD5870 O.C. Edition
-- Windows 7 Ultimate ed. 64-bit
* 4:3 17' monitor W/O HD Support
I built the system myself and as for this was the first system I put together, I was concerned that I might do sth. wrong but everything seems to work fine except for the display in games. I don't know the reason; but the games get stuck (i.e. HL2, L4D) and I can't rate my hardware through the Windows Rating System because it also gets stuck while testing Direct3D support.
The screen when the computers stucks has yellow and black vertical lines from one end to the other.
So I thought that this is somehow a Graphic Card failure; but then again, it might have something to do with the non-HD monitor that I own from my earlier setup.
I don't know what to do and I don't want to mess with the stock values of the hardware.
If someone would help, I'd appriciate it.
*ps.: It runs the game Left 4 Dead or Just Cause 2 for about 1-2 minutes AND stops.
The specs:
- MSI 890-FXA
