Yes No
Ads
GTS 250 problem
Forum Graphics & Displays : Graphics Cards GTS 250 problem
Related Content
Can't find your answer?
Ask!
Specs
Gigabyte GTS 250 1GB
Intel core i5 650 @ 3.6 GHZ
GIGABYTE GA-H55M-S2H LGA 1156
4 gig Ram
Huntkey True AFPC 700W Power Supply
I ran Gpuz and I says my graphics card is only running at PCI x4 instead of x16. How do I fix this?
Reply to BoerRepublic
Ahh... Try re-seat the card, that should help you fix your problem... :)
------------------------------ Core 2 Duo E6300 1.8 GHz (OC at 3.0 GHz) / Zigmatek HDT S1283 CPU Cooler / Gigabyte GA 965P-DS3 Motherboard / 2x1 GB DDR2 800 RAM / 2x160 GB Seagate HDDs / SilverStone ST50F 500W PSU / HIS IceQ 4 HD 4850 512 MB DDR3 / 17" LG Monitor
(Little Dinosaur)
Reply to wa1
I have a x16 and a x4 and it was actually in the x4 slot so i moved it to the x16...... but it now says it's running at x1 :(
- 0 +
already tried re-seating the card?
Not long time ago i also suffering from the same problem like yours, instead of x16 my pcie speed is x4, so i re-seat the card and my card goes back to x16...
(Little Dinosaur)
Reply to wa1
It was x4 cause it was in the x4 slot so i moved it to the x16 slot but now it's only running at x1
- 0 +
Yes, i heard you. Now, even your card already on x16 slot, have you re-seat it again? Re-seat=unplug and plug it again to your x16 slot?
If your card isn't properly attached to pcie slot then it could make issues like yours (x8 - x4 - x1).
(Little Dinosaur)
Reply to wa1
I've taking it out the slot and unplugged the power cable, twice and needed to re install graphics drivers
- 0 +
ANd make sure you install the proper driver for your card...
Just do it slowly, even i must re-seat my card 2 or 3 times to get the actual speed (x16)...
(Little Dinosaur)
Reply to wa1
I've done it 3, times installed the old driver that came with card....garn back to the new drivers. :( it's laging in everything I'm just going to go back to x4
Have you tried resetting the BIOS and running without an OC on the CPU?
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
Resetting the bios by removing the battery?
Sometimes you may have to move a jumper to reset, check your motherboards manual for resetting CMOS.
I reset CMOS and took off CPU oc, still at x1
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > GTS 250 problem
There are 1744 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 1 hour ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
