Hello, this is my first post with this site, hopefully I have it in the right section, and some of you can help me out.
I'm finding parts for a new system build. I would like it to be upgradeable and semi expandable for the future.
My current build that I plan on getting is as follows: (Don't judge me, for some things I'm going for complete overkill, and I prefer it that way
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058&Tpk=antec%20nine%20hundred%20two
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131655&cm_re=890-_-13-131-655-_-Product
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103692
Ram: -2x- http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3891137&SID=194r0
for total of 8gb ram.
DVD/CD drives: -x2- http://www.buy.com/prod/dvd-r-rw-dl-ad-7260s-0b-sata-24x8x12x-24x6x12x-bulk-black/q/loc/111/215781592.html
Hard drives: -x2- http://www.wdc.com/en/products/products.asp?driveid=610
Power supply: http://www.highpowersupply.com/HP550G14S.html
Thats What I have come up with so far. Probably with those things will cost about 770$ total.
Now, I need to find a good reliable CPU cooler.
And a good but not crazy-illy expensive graphics card, but one that can support decently high end games, I would be very great-full for some ideas/suggestions.
As far as I know everything I listed up there is all compatible, as for the things I would like some advice or suggestions for, I have no idea.
Any preferences for swapping parts for different ones, or things I have forgotten etc, would be GREATLY appreciated.
Regards-
John Maich
Regards-
John Maich
